flat tappet to hydraulic roller conversion
Old Jul 7, 2003 | 03:31 PM
z86roc28's Avatar
I have seen several different companies making retro fit roller lifters for a hydraulic roller cam to be fitted into an early style block, however, who makes the best? Has anyone had problems with a particular brand? Also, I have seen timing chain sets listed for 55-86 SBC and 87-92 SBC. Which one would I use with an early style block and a HR cam? Machining required?
Old Jul 7, 2003 | 04:04 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Most retro cams are made to accept early timing chains and need no block machining. Best to check with the manufacturer. In my vette I am running a crane retro cam with iron dist gear so I did not have to change my dist gear. You will need shorter push rods and diff springs. You would be best to switch to a head that has screw in studs.
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
hartsmike
Oct 2, 2015 07:11 AM
mfp189
Sep 27, 2015 09:25 AM
