Adding Tpi To Older Small Block
Old Jul 25, 2003 | 10:27 PM
stardog's Avatar
Is it possible to add the TPI to an early 70's small block?
Old Jul 25, 2003 | 10:41 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yes, it's just an intake manifold. The only catch is, in 1987 GM changed the angle on the center 4 bolt holes so if you want to bolt an 86-up manifolds to early heads you need to slot the holes a little to let the bolts go through right.
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
