injectors.....one set bigger?
Old Aug 3, 2003 | 09:55 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
can anybody tell me if 1988-L 98 injectors, and 1989 L-98 injectors are the same , the 1989 set are bigger in diameter. i have both sets and im going to use one of the two sets. their going in a 383 stroker motor. are they both 22# pound injectors???
Old Aug 3, 2003 | 10:43 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
They are suposed to be. Did u chk to see if they are the stock ones u have? I got 24# injectors in my 383 and I am still close too lean.
Old Aug 4, 2003 | 02:40 PM
stuart's Avatar
yes, they are both stock.....do you know if they are 22# pound injectors?...im running ported & polished vortec heads, scoggins dickey vortec alunimum intake, 383 balanced rotating assembly, edelbrock headers with cat back exhaust, 1.5 self aligning crane roller rockers, tpis zz-9 cam, edelbrock hi-flo runners,msd 6a-L,ported plenum,and a custom chip. do you, or does anybody have this simular setup?.....if so what kind of numbers should i expect from this combination?....thanks
Old Aug 5, 2003 | 04:25 AM
Tyler-88's Avatar
im building a wild 383, and after hours and hours and hours and hours of reading i went with SVO 30# injectors. try the search button to see why i chose them if you dont belive me
Old Aug 5, 2003 | 08:30 AM
stuart's Avatar
do you have yours together yet?.........if so, how is it working for you?
Old Aug 6, 2003 | 12:47 AM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
Yep, they both flow the same. The difference you see is 89's went to a "multec" injector. Supposedly better but I wouldn't bet on it
3.8TransAM
Sep 3, 2015 06:38 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Thornburg
Aug 27, 2015 08:33 PM
Keith5
Aug 27, 2015 04:37 PM
mustangdmurder
Aug 21, 2015 07:17 PM
