Can stock 86 tpi put out 270-280hp from 350 swap?
Old Aug 18, 2003 | 04:13 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
Just wondering with stock injectors too swap very soon.
Old Aug 18, 2003 | 04:45 PM
fbody_freak's Avatar
I don't understand the question.
Please clear it up a bit. What are you swapping in, what parts, mods, etc...
Old Aug 18, 2003 | 05:09 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
go to my webpage. click the blue banner. i own a 1986 TA
Old Aug 20, 2003 | 02:05 PM
IROCME's Avatar
Car: 1986 IROCZ
350 SWAP
I am swapping in a 270-280 350 asnd use the stock 86 tpi iroc injection I was wondering if it could support it
I also plan on using a stock 88-89 350 tpi prom good idea??
Old Aug 20, 2003 | 05:39 PM
mrr23's Avatar
Engine: 360 HSR
yes it will support it except for the injectors. it will run lean. put an adjustable fuel pressure regulator on it. set it for 52 psi with vacuum line off.
Old Aug 20, 2003 | 07:00 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Depends on what intake setup was used to get that 270-280 hp number. If it was a higher flowing carb setup, as is usually the case, then you can expect to loose hp with the tpi, especially up high. Stock 19# injectors should be ok with that power level, like said you'll need an AFPR, and maybe chip tuning to get it to work perfectly.
I ran a stock tpi with stock 19# injectors, and a Performance Resource chip for a 305 on a 357 with about the power you are looking at, and had no problems at all.
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
armybyrd
Aug 10, 2015 09:23 PM
marcusaw
Aug 10, 2015 08:13 AM
gwade12
Aug 8, 2015 08:17 AM
