Will FP regulator be the cause of my backfire and surge?
Old Aug 20, 2003 | 11:40 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I've posted in this room about a massive backfire after highway driving.
https://www.thirdgen.org/techbb2/sho...hreadid=196934
I started into some diagnosis as per the Pontiac service manual. I have a Fuel pressure guage on my rail and noticed that after initial prime and and/or engine start, the system will not hold pressure after shutdown or I turn back the key. So I went throught the test. When I came to the step of pinching the return line off to the tank, the pressure held. Since doing this the pressure is continuing to hold. Its an adjustable regulator. Can this be the source of my trouble?
Old Aug 23, 2003 | 01:30 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
The pressure always bleeds off when you turn the car off and doesn't build up again unless you restart the car or turn it off for a long time.
If you have an AFPR, your pressure could be too high and cause the symptoms you describe. If your engine is stock, stay within 5# of stock setting. Either way, if you go too high you will basically flood the engine or freeze the injectors open.. That point depends on the calibration of your prom and brand/condition of your injectors....
Mark_ZZ3
May 24, 2018 01:02 PM
gixxer92
May 18, 2017 11:20 AM
racereese
Oct 3, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
