Superram gurus
Old Aug 26, 2003 | 08:10 PM
StylnCamaro's Avatar
Superram gurus
I had a question about my superram. Not the plenum or runners but actually the intake itseld. I bought this setup used and when I got it, I seen there is a pan of some sort bolted to the bottom of the intake. What is this pan and what is it's purpose? The reason I ask is because I noticed 3 out of the 4 bolts where snapped right off and just barely being held in there so I have to get them retapped if it plays an important part
Old Aug 26, 2003 | 08:34 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
i know what your talking about.... I think it helps keep the hot oil away from the bottom of the intake and keep the baseplate cooler. (cold air flowing through the intake is best). i put on an edelbrock high flo intake but forgot to take that part off my stock intake and and attach it to the edelbrock base. i realized my mistake after the base and super ram were completly installed.. so i was in a spot take it completly apart and start over or hope that it wasnt to important and the car would run well......... i never installed it and the cars running great ... when i do a ZZ4 i'll fix it.... so you really dont need it but if ya think you can drill ,tap and use it it can't hurt to have in...........Eric
Pac J
May 17, 2020 10:44 AM
GTAman
Sep 21, 2015 09:57 AM
'87FAKE-IROC-Z
Aftermarket Product Review
Oct 9, 2001 03:31 PM
Chaotic Firehawk
May 4, 2001 05:53 PM
TheFormula350
Aug 1, 2000 12:25 PM
