Code 33 / LT1 Conversion
Old Aug 30, 2003 | 09:50 AM
Formula383's Avatar
Car: 88 Firebird Formula
Anybody who did the LT1 conversion getting a code 33. Seems to be for me that everyonce in a while I'm getting this code. I know there is a problem with the TB but I can't see this being the problem.Any idea's.
Old Aug 30, 2003 | 12:20 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Is your TPS set correctly? If the TPS is set incorrectly then it can cause a 33 to show up.
Old Aug 30, 2003 | 01:11 PM
Formula383's Avatar
Yes the TPS is set correct but then again.The problem that I am having with the TB is the casting that the shaft goes through is worn out a little so I have a little bit of a high idle. I don't know since that is happening w/ the TB if that will throw off the TPS.
Old Aug 30, 2003 | 01:58 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
My understnding is the code 33 being related to the TPS, is to set the TPS voltage higher than spec...i/e .6 or so.
And for some reason I'm thinking this may only apply to SD cars...not really sure....but worth a shot to set it higher an see.
BumpaD82
Feb 26, 2016 02:57 PM
LittleFranks
Oct 7, 2015 11:26 PM
L0tuS
Oct 4, 2015 08:07 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
L0tuS
Sep 4, 2015 11:16 PM
