somebody lend a hand please...... PLEASE
Old Sep 17, 2003 | 02:28 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Ok here's the deal: My '91 L98 spun the rod bearings. In order to save time, I got my hands on a rebuilt 350, the older 2 piece rear main seal style, and a 4 bolt main. The engine itself has a few minor mods, being overbored and a bit more aggressive cam than stock. I also took the time to install an '89 corvette TPI intake, siamese ported and polished (courtesy CEcoatings.com), and some siamese ported SLP runners and plenum, again from Cecoatings.com. On to the (not so) fun part. I have the engine in the car, everything hooked up, and it will not start. The engine will crank fine, but there is NO spark or fuel to the system. I have verified power to the ECM, power to the ignition coil, and proper ignition timing, but there is no spark coming out of the coil and no pulse out of the injectors. The SES light gave me a code 46, a VATS code and it's telling me to look at CKT 229.....? Could anyone shed some light on this situation because I'm stuck with a car that won't start.... thanks.
Old Sep 17, 2003 | 05:04 PM
Zip a dee do dah, zip a dee yay........
Found the problem. Thanks for looking anyways. It was a bad VATS module.
Old Sep 17, 2003 | 07:51 PM
RP1987GTA's Avatar
how did you isolate the vats module?
Old Sep 18, 2003 | 12:10 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Old Sep 19, 2003 | 09:28 AM
Kind of hard to explain in type, but the module will ground A2 and A3 lines going to the ECM (don't quote me I don't have my diagram here) if it's working properly. I couldn't believe how easy it was to bypass. I simply unplugged it, and the car fired right up! :lala: I thought it wouldn't fire at all. Oh well, at least it works. I can't wait to get this new engine broken in and get some track times yay.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Sep 29, 2015 10:18 PM
