performance
Old Oct 15, 2003 | 09:23 PM
IROCthis88's Avatar
Car: 1988 iroc-z all stock for now
Engine: LB9 305
Transmission: 700R4 3.42 posi rear
performance
i have a stock tpi 305 in a 88 IROC, i want to put in a comp cams LT1 cam rated @ 212-218* @.050" lift with 488-495 inch lift on the intake & exhaust. i'm planning on using the world s/r torquer 305s with the cam upgrade. i want to know what the timing should be set at with this change over and if someone can give me a rough estimate on the power i may be making with my set up, the car came stock with the LB9 automatic and 3.42 gears. any info on this is greatly appreciated :hail:
Old Oct 15, 2003 | 09:26 PM
IROCthis88's Avatar
Engine: LB9 305
performance
i meant to say duration is 212-218* @ .050"
Old Oct 16, 2003 | 01:21 AM
Morley's Avatar
The timing should stay at the factory 6* BTDC unless you can burn chips, then you'd play with your base timing and see where it likes it best at idle.
Old Oct 22, 2003 | 05:23 AM
IROCthis88's Avatar
Engine: LB9 305
a friend of m ine told me last night that the cam i have for the 305 wont work, he said that the 305 will only take up to 480" lift. is this true or can i get away with this upgrade???
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
