injector constant help!
Old Dec 1, 2003 | 07:53 PM
chevyboy07 91's Avatar
hey guys, the last prom that was burned for my car i think included a 22# injector constant. I am having some idle surging problems but really think its my FPR (long story) Ohh, I am now running 24#ers
Anyway, do you think the wrong constant is contributing to my idle problems?
I have a new pump, no pulse damper, new injectors. Pretty sure my reg is the problem but what am i hurting by having the 22# constant? Am i down on power, or pushing the injectors harder, etc??
thanks
Old Dec 2, 2003 | 10:30 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
using the incorrect injector will cause surging.
ie your case, stock 22# constant using 24# injectors will cause the problems you describe.
if the FPR is leaking repalce it asap!!!!!
Old Dec 2, 2003 | 05:08 PM
ok, but what's weird is when i built the new motor, i HAD 22#'ers and it was still running like crap with the surging, etc. There was no difference between the 22's and 24's in idle behavior.
My regulator does not leak and am pretty dang sure there is no vac leaks ANYWHERE...but im still thinking its messed up.
Old Dec 2, 2003 | 07:21 PM
Car: 1988 IROC-Z
check the fpr vacuum line for liquid fuel. that the most common and overlooked fault with FPR.
92-Formula
Dec 12, 2015 10:34 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
