Comp 987's too much for LPE 219??
Old Dec 3, 2003 | 12:35 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Who think's the comp 987 sping is too much for the LPE 219 cam with 1.6RR=.560 lift? I did searches, some people say they are great, and some say they are too much.
Old Dec 3, 2003 | 12:53 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
They will work fine!
Old Dec 3, 2003 | 02:54 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Both LPE and CompCams said that the 987's are the proper springs. LPE now sells Lunati stuff though so you may want to check that out. The ramps on the "219" cam need a beefy spring.
Old Dec 4, 2003 | 06:49 AM
Car: 91Z
Perfect, I was just being iffy because I did a bunch of searches, and some say they are fine and some are not so sure. I am going to order them today, thank's guy's. I really get's me that AFR charges $2000+ Canadian for heads, and can't even give you a decent valve spring.
Old Dec 7, 2003 | 10:36 PM
Corvette0096's Avatar
That is the same spring I am running with my 219. Set pressure is #110 and open #320. That was with some machining of the heads.
Pac J
May 17, 2020 10:44 AM
no green
Jan 9, 2016 09:22 PM
