Wicked Confused about 350 injectors
Old Dec 31, 2003 | 10:40 AM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
Every magazine i read, the mag says the 350 uses 24 lb/hr injectors.
Every person in here says they're 22 lb/hr injectors.
Which is right?
Old Dec 31, 2003 | 11:11 AM
llvll4l2c91350's Avatar
22 for stock TPI 350's.
i think 24's came stock in LT1 motors
Old Dec 31, 2003 | 11:41 AM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
Yep, 22s in the 350tpi and 24s in the 94-97 LT1s (the 93 F-body LT1s still used 22s)
Old Jan 1, 2004 | 01:13 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Which is right?
It really comes down to how much HP each injector is servicing.
On a stock 350 TPI motor each injector is servicing around 31 hp.
Say on a 500hp 350 each injector needs to support 62-65 hp, so obviously the injectors need to be larger, but the displacement is still 350.
Get it?
-- Joe
Old Jan 1, 2004 | 01:25 AM
Morley's Avatar
85 Vette 350 used 24# inj, at a little lower pressure.
Old Jan 1, 2004 | 09:47 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I've used 24# Accel Injectors in my 89 TPI for several years now without modifying fuel pressure, etc... the car runs fine.
Old Jan 1, 2004 | 12:24 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well the ecm will correct the fuel differences via o2 sensor. But most of us would rather drive around in a car thats tuned, rather than constantly correcting.
You prolly run a little rich under PE (wot) however, but I guess that never hurt anything.
-- Joe
Old Jan 1, 2004 | 02:12 PM
Morley's Avatar
-- Joe
not to mention rich at cold start (open loop)
MustangBeater20
Oct 29, 2022 09:20 PM
xxx3man`
Aug 28, 2015 02:21 PM
twest2k2
Aug 24, 2015 11:26 AM
86IROC112
Aug 21, 2015 07:20 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
