fuel injector questions
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I just got some injectors, 2 of the pintle caps are busted, 1 is gone completely, the other is cracked and missing a piece. Will this cause problems?
Also the part number is 5235047. Any info you can give me on that?
Thanks,
Matt
Thanks,
Matt
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yes. You should be able to get replacement parts though.
Couldn't say for sure. It's worth a shot. These stores are carrying more and more EFI stuff every day. You may get lucky and find a HELP! package of them. The injectors are standard Bosch style, and were used on a lot of different car, so the parts should all be pretty much universal.
Firechicken86
Aug 12, 2015 10:07 PM
