NEED before I blow a rod!
Old Jan 9, 2004 | 02:19 AM
Cracker's Avatar
Car: 85' Trans Am
Engine: L-98 Vette engine
NEED HELP before I blow a rod!
Just today I had a plug foul out...so I replaced them....I feel it is because I am running too rich...well I thought I had a while before it would foul out again...well it fouled out within two hours...I really only know carbs on how to fix that. So How would I fix my TPI so I wont run so rich???
Old Jan 9, 2004 | 07:52 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Get yourself some books on tuning and modifing tpi systems, they have kinds of trouble shooting instructions, then when you are reading to proceed check back in with specific questions. There are too many thing that could cause what you are experiencing for people to guess at.
Old Jan 9, 2004 | 03:24 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Are you running a custom chip for your L98 swap, or the factory LB9 ECU set up???
Old Jan 10, 2004 | 02:07 AM
Cracker's Avatar
Car: 85' Trans Am
I found out what the problem, was/is....I figured I should do a few things before I mess with the injection system...well I have bad news....I decicded to do a compression test on my car...well found out that it is off....meaning I have two bad piston rings. eerg!! So I am ordering a rebuild kit with performace pistons that are 0.030in bigger than stock...and then ofcorse bore out my block...so I guess its all for the better "take the bad with the good" So now I had a problem going to fix that and all my leaks....and at the same time get more power!! woohoo...
tanks anyways guy!
Old Jan 13, 2004 | 11:20 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
So you figure you have two bad ring sets, right?
How did you arrive at the conclusion? Tell us how you ran the test and what the readings were.
Jake
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
Fanatic1074
Oct 2, 2015 03:47 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
