Head/Baseplate Compatability
Old Jan 20, 2004 | 01:32 PM
onebadassbird's Avatar
Car: 91' Trans Am
Im thinking about ordering the GM Goodwrench 350 Crate from Summit:
http://store.summitracing.com/partde...NAL%2D10067353
I want to use the heads on it, get them ported. The only problem is that I want to use the TPI set up on it. Does anyone know an aftermarket baseplate that would bolt up to them? I heard TPIS' has one. Or this may be a stupid question but will the manifolds ment for the 82' - 92' heads bolt on?
Old Jan 21, 2004 | 09:00 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm pretty sure all the aftermarket baseplates are "dual pattern"...ie the center 4 intake holes are pre-slotted..least my Accel intake is.
Are you looking for performance?
If so, I don't think I'd spend time on the crate engines heads...you probably would do better with a better shortblock, and purchase a good set of heads.
Old Jan 21, 2004 | 09:04 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Another thing...is your '91 a L98..i/e a 350? If so, your current heads rebuilt, would give you more performance on the same shortblock listed, than working on the 76cc heads.
Old Jan 21, 2004 | 11:14 AM
Car: 91' Trans Am
Yea I was thinking about looking through the local papers and trying to find a nice shortblock, Sounds like a good idea. My 91' is an LB9 thats why I want to do the swap.
