Fuel Pump
Fuel Pump
I am having a problem with what I think is a fuel pump fuse. On a TPI car where is the fuel pump fuse. I tried changing the fuel pump, but that didnt solve anything. The motor turns but doesnt fire up. If it doenst end up being the fuse, what else could it be? I really need to get to the bottom of this.
Car: 1988 iroc-z baby! :o)
Transmission: soon 2 be replaced.
the 20 amp fuse in that plastic housing bolted behind the headlight housing by the battery i think........i may be wrong....try doin a search
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On the fuse block there are two fuses for the injectors on TPI cars. They are labeled inj.1 and fp/inj.2. FP/INJ2 is the fuse for the fuel pump, there is another 20 amp fuse located in the engine compartment that is the fuel pump relay/ECM. Since you have stated in your post that the engine turns but won't fire, that fuse is ruled out. When you turn the key, do you hear the fuel pump prime. It might also be a bad fuel pump relay which is mounted on the driver side firewall in the engine compartment.
The Trickster!!!!!!!!!!!
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
