Need help! Vortec TPI with L31 heads
Old Feb 20, 2004 | 05:41 PM
My85TA's Avatar
I'm trying to put together an engine for my 85 TA. It now has a 305 TPI. I am wanting to order a shortblock with the L31 vortec heads and putting a Comp 260AH-12 cam in.
Will the upper part of my TPI from the 305 work.
What size of injectors will I need to get, considering I would like to later add a 100-150 shot of NOS?
Also what is a good ignition to go with?
Old Feb 20, 2004 | 07:30 PM
Shaun 90 Iroc's Avatar
Car: 1990 Iroc-Z
Engine: 350 L31 Vortec
you would need a TPI vortec baseplate ($400) to use vortec heads and TPI. 24 lb injectors..
Old Feb 20, 2004 | 10:13 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Need help! Vortec TPI with L31 heads
Yes the upper part works but it's still a long runner intake which will focus power in the lower rpm range, so you might look into the RamJet intake instead.
24lb injectors would be cool. If you do your own proms a lot of sizes would work properly.
Stock ignition is good. Just make sure cap rotor, coil and module are up to snuff.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
