fuel injectors
Old Feb 25, 2004 | 07:20 PM
NatesL98's Avatar
Car: 1990 Iroc-Z
fuel injectors
what are the stock size fuel injectors on a '90 5.7 iroc? I thought that I read somewhere that they were 22#. If I go up to 24# or25# injectors will I need to do anything to the prom. Will injectors from a mustang work? I heard that they are all the same design.
Old Feb 25, 2004 | 07:56 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
22 lb injectors for 5.7.... 19 lb for 5.0..... Yes you will have to get the chip reprogrammed if you go w/ bigger injectors or you're car will run lean, you could get a APFR and try to temporarily adjust it that way, but it's best to get the chip reprogrammed. I have read on the board that people run SVO injectors w/ no problems so you can use mustang injectors.
Old Feb 26, 2004 | 01:23 AM
superv's Avatar
Car: 90 Iroc
Engine: 355 C.I.D. tuned port
Hi, my Iroc had 19 pound hr injectors from the factory
cuz original engine was a 5.0 tpi (now 5.7)
IM running 9.75:1 forged trw pistons and ford 24pound hr injectors, and an adjustable fuel pressure regulator
Im still running on 5.0 prom, cuz just too lazy
car runs perfect, due to the ability to adjust the fuel pressue,
Im going to update prom, but for now, car kicks *** as is
Old Feb 26, 2004 | 10:20 AM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
you can get 25lb/hr injectors from SLP for $100 for the whole set. They are LS1 injectors. I put them in my 91z and they worked great.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
