headers/intake manifold
Old Feb 28, 2004 | 11:00 AM
microtek_10's Avatar
Car: 92 Z28
Engine: 355 tpi
Ok, i have 2 issues here. I did a search on both and couldn't come up with what i was lookin for. First, Hooker shorty headers. How easy are they to install? I'm talkin about whats the best way to go (top or bottom), and what all needs to be removed to get the headers in there?
Second, a new intake manifold on a 350 TPI. How easy is this to do yourself? My buddy just did his on a 350 but his is carbed so i wasn't sure if it would be much harder on a tpi setup. Any responses would be great. Thanks in advance.
Old Feb 28, 2004 | 12:02 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I put in Hooker Shorties but I pulled the heads and replaced them at the same time. Driver side has plenty of room. Passenger side would be a bear with the heads on, it would have to be done from underneath. TPI intakes aren't hard, just have to take your time and watch the clips on the injectors.
Old Feb 28, 2004 | 05:05 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I have Hooker Headers and they are not hard and fit rather well but the Passenger side is a pain due to the Tranny dip stick and the AC stuff. I just put heads on and it was a pin with them tring to get them off. The intake is easy as pie. Just remember where everything goes, vaccume and so on.
Old Feb 28, 2004 | 05:29 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
Yeah, the only thing to worry about with the intake is the vacume lines. MARK ALL OF THEM!!!!!When I did mine I didn't mark any of them and it took forever to figure out where they all went. Also make sure you torque the bolts down too otherwise you will have vac. leaks.
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
