EGR help
Old Mar 11, 2004 | 06:13 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
EGR help
i have a 91 z28 convetible(305 TPI) and i think the EGR valve is bad how excatly do i check that since its location and can some1 please give me the steps on how to change it please thank you
Old Mar 11, 2004 | 06:25 PM
badtpiluck's Avatar
Car: 1985 camaro RS
Engine: 350 cid
Just curious, but what are your symtoms. Im having problems also and want to see if there the same as yours
Old Mar 11, 2004 | 09:37 PM
loss of horsepower and rough idol mainly and um............i get the egr code
Old Mar 12, 2004 | 10:38 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I recently changed my EGR Valve, Harness, and Solenoid.
The EGR Valve is attached to the intake manifold by 2 bolts.
There is also a wire you have to disconnect... it is about a foot long and has a connector you simply unplug.
When I changed mine, I also needed to fix an intake gasket leak so I pulled the entire manifold off.
Hope this helps.
Old Mar 12, 2004 | 12:40 PM
Morley's Avatar
No wire in the 1990-1992 TPI EGR valves, it is for the diagnostic feedback switch, they don't have it.
To check your EGR valve hook a vacuum pump to the valve and place a small inspection mirror where you can see the bottom side of the valve. Apply vacuum and see if the diaphram moves upward (underside of the valve), if it doesn't move, replace the valve. If it moves, see if it stays open until you remove the pump, if it does, the EGR valve is good. next hook the vacuum line back up to the valve, start the engine and let it get up to operating temp, while watching the diaphram i nthe mirror, rev the engine and see if the valve moves, if it doesn't...disconnect the connector from the solenoid and hook a volt meter to it and rev the engine again, if you get voltage replace the solenoid, if not you have a wiring problem.
If all of the EGR checks out good, try replacing the coolant temp sensor. I had the same problem on my 91 formula, along with a ck eng lt (EGR code), EGR gasket was not there. Replaced the gasket but the bad idle and stumbling was still there. Turned out to be the CTS.
Old Jun 6, 2007 | 04:41 PM
TPI-RS's Avatar
Car: 1991 RS Hardtop
Axle/Gears: 3:23
Re: EGR help
Morley:
You said there is no wire... I'm building a motor out of an 88 IROC and putting it into a 91 Z28. The new wiring harness doesn't have a connection for the plug on the EGR... Just leave it out? I was told it will run bad if its not plugged in, but there is no place to plug it in... Any advice you have would be good
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
