equation for fuel injector size vs. PSI
Old Mar 15, 2004 | 07:21 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Someone remind me what the equation is for fuel injector size at a give psi.....
it would be good for the search engine too
Old Mar 16, 2004 | 01:02 AM
viperwsu's Avatar
Car: 91 Camaro RS
Chevy Thunder has the equations I think you are looking for.
Was this it?
(Maximum hp) X (brake specific fuel consumption) / # of injectors= lb/hr
Old Mar 16, 2004 | 12:56 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
it should be the square root of the new pressure divided by the old. Then take multiply that by the injector's rating at the old pressure. #lb*(New psi/Old psi)^.5 as an example, 30lb*(45psi/38psi) ^.5=32.6lb
Old Mar 16, 2004 | 01:05 PM
OMINOUS_87's Avatar
http://www.rceng.com/technical.htm#WORKSHEET
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
killer777
Aug 8, 2015 02:47 PM
