LT1 cam in a L98?
Old Mar 19, 2004 | 10:58 AM
Raiden's Avatar
LT1 cam in a L98?
Can I put a lt1 cam in my l98? Looking at the lt1 cam that spec's out at .050 210/224 on 112 lc. I know all that need to be done with the lt4 hot cam is to grind off some of the dowel???
Old Mar 19, 2004 | 01:21 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Yes it'll fit by grinding off the pin but I don't think those are the specs on an LT1 stock cam. They have almost the same duration as a stock L98 cam.
Old Mar 19, 2004 | 01:44 PM
vwdave's Avatar
Thats like, adv duration.
Old Mar 19, 2004 | 01:58 PM
Raiden's Avatar
Well, it's bigger than what I have in currently. I have a zz3 cam that spec's out at .050 206/220 on 112 lc. I think I"m going with a comp cam's 212/218 on 112 lc. That cam will be perfect with my AFR heads and supercharger. I have tons of power as is, however, my current cam is a regrind and I think the grind is off in duration on cylinders 3 and 5....this is a long story. Anyway, going with the comp cam instead of the lt1.
Thanks for the help, greatly appricated!
lt500r55
Sep 1, 2021 01:30 PM
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
midge54
Aug 29, 2015 09:51 PM
TheExaminer
Aug 19, 2015 10:07 PM
