HSR and tuning?
HSR and tuning?
I am interested in buy a HSR Intake and maybe a set of decent heads. I have seen where the stock PROM with the HSR will go very lean higher in the rpm range. I know a burned PROM would be the best, but i can't do that and only person i know of is ED Wright. I have alittle time to get this done before a local streetcar race in 1 month.
Could I install bigger injectors to richen up the mixture so it doesn't go so lean to hurt anything?
What size injectors..24lbs...30lbs?
I know down low it probably won't be the best thing, but i figure that is what the O2 is for and it will pull fuel out of it.
What do you think? I am spraying 175N2O and probably be pilling up later. So I want to make sure the motor is not lean before, before i pill up.
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Burning a PROM yourself or getting one custom-burned for you is the only right way to go about this. You can get a mail-order custom PROM through PCMforless for $150. Its hard to justify running the stock tune when you can get custom programming so cheap.
Car: 1990 Iroc-Z
True that... there is no good way to skip the prom.
You can get an AFPR and smudge the fuel pressure to band-aid, but it won't come halfway near what the prom will do for you.
Car: 1990 IROC-Z
Engine: 350 L98
get a new prom... and make sure your fuel pump can handle that 175 shot. you also might want to get a MSD Digital-6+ or something of the like to retard your timing so you dont run into any problems with that high of a shot. you dont want to blow your engine and be out of a car for a while
get yourself an AFPR (HSR fuel rail w/ AFPR) and 24# svo injectors with the new prom. When you get your custom chip, they'll tell you where to set the fuel pressure with those injectors. i wouldnt start the car unless I had the new chip in it first.
HSR likes more timing and more fp at higher rpms. You'll definately need a new custom PROM if your going with the HSR. have fun, and enjoy! let us know how everything goes
