Accel injectors
Old Mar 24, 2004 | 01:04 PM
Eric's Avatar
Car: 87 GTA
Accel injectors
I am considering that I might need new injectors. My 87 GTA is basically a stock L98, so I don't need big-flow injectors. I was snooping around and found that Jegs and Summitt both sell the Accel injectors for a good price ($230/set).
Does anyone have any experience with these particular injectors? Or can you recommend good ones? I am on a fairly tight budget, so the price of the Accels appeals to me.
Old Mar 24, 2004 | 01:17 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Accel injectors
This questions been asked a million times...Some will tell you Accel is junk and others will not. I did not like mine so i switched to Ford SVO's. They are a little cheaper. Some people wont burn proms if you have Accel injectors. Do a search and decide for yourself.
Old Mar 24, 2004 | 02:13 PM
Everett#2390's Avatar
Car: Several
Engine: A good heart
Transmission: Long legs
I bought a set of Accel 24# injectors and I either haven't put enough miles onto them, ie, 300, or I don't know what I'm looking for. Educate me.
I didn't reprogram either from a 305 chip, but, the car does run better, but still have low idle speed and no fast idle when cold, same as before injector changeout.
Yes, ECM has been replaced, new chip, and new IAC. Base rpm set, intial timing at 6* BTDC, IAC connector has good continuity to ECM and has signals to control IAC. Vacuum gauge shows 20 in/Hg.
I appreciate any suggestions.........
Old Mar 24, 2004 | 06:20 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
i had the accel 24# injectors in my new motor and they leaked so bad i changed my oil 7 times in 1300 miles.....but ive heard other people having good luck with them.......im now using the svo`s and no troubles as of yet........just my .02
Old Mar 25, 2004 | 12:58 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I have had Accel 24# injectors in my 350 TPI for about 3 years now with no problems.
92-Formula
Dec 12, 2015 10:34 PM
85 Jimmy
Sep 30, 2015 07:56 AM
BAMiller
Sep 14, 2015 06:38 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
