Pinging, missing, and backfiring on ZZ4
Old Mar 30, 2004 | 09:40 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
My dad has a 90 Formula with a 350 ZZ4 Crate motor with SLP runners, lingenfelter intake, edelbrock headers, and a Flowmaster catback. Lately when the engine is warm it has begun to ping, miss, and sometimes backfire under light acceleration.
To date I have checked the timing (6 degrees), changes plugs, then changed the gap from 35/1000s to 45/1000s. Then I replaced the EGR valve and finally disconnected it. Nothing seems to help. Any ideas?
Old Mar 31, 2004 | 07:42 PM
KYL98's Avatar
Car: 1991 Z28
Maybe a faulty or bad Knock sensor??? Maybe some bad gas? What octane is he using? I would only use 93+ for any V8........
Old Mar 31, 2004 | 07:58 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
yeah, i was about to say i hope your using 92/93 octane if you start to hear pinging. set your timing at 8* and see if that helps some. whats your fp set at?
Old Apr 1, 2004 | 07:16 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
-------------Sorry for the misinformation, but the timing was set a 6 degrees before and after their were problems.
I was told that the mechanic did a compression test and it was fine. I can get the actual numbers soon.
My dad is going to pick up some octane booster tomorrow.
It's not the gas, because we have filled up with different gas, and still have the same problem.
I'll have the mechanic find out what the fp is at soon.
Old Apr 13, 2004 | 02:23 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The problem turned out to be the distributor shaft. The magnets were not working properly I believe.
Old Apr 14, 2004 | 01:37 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I hate it when those darn magnets decide to act up!
Fireslash
Apr 11, 2016 06:43 PM
racereese
Oct 3, 2015 03:46 PM
BrianI
Oct 3, 2015 12:57 PM
lewandom
Oct 1, 2015 08:15 AM
