egr and vacuum troubles
Old Apr 4, 2004 | 04:22 PM
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
i don't know much about my motor or its workings, but i was changing a gasket and found some busted vacuum hoses and i broke a sensor..
i broke this and need a new one. whats it called?
this hose is broken:
i assume i can take it to lordco and ask for a new one, but i dont know where the other end plugs in.
another broken hose (this where the egr one goes?)
rear pass side of plenum (the one with no hose was.. you guessed it.. cut)
i need to replace that which is broken? can anyone help with part numbers or advise?
Old Apr 4, 2004 | 05:08 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
That looks like your EGR sensor. I "think" they sell those without having to buy a new EGR. The hoses you broke are EGR hoses. You can buy that hard line vacuum hose at any parts store. It comes in like a 12" roll.
Old Apr 4, 2004 | 05:10 PM
theSteve's Avatar
Car: 1985 Trans Am
lol hey! i didn't break those hoses! they were already like that.
any idea where the egr vacuum hose plugs into? (the other end)
Old Apr 4, 2004 | 05:30 PM
Morley's Avatar
That is the EGR diagnostic or feedback switch. They run about $10 at most auto stores.
Old Apr 4, 2004 | 05:31 PM
theSteve's Avatar
Car: 1985 Trans Am
sweet thanks
any ideas on the vacuum hose plug?
Old Apr 4, 2004 | 07:50 PM
Morley's Avatar
Originally posted by theSteve
sweet thanks
The back port on the plenum goes to the cruise control, there should be a long vacuum hose from the cruise leading back the driver side and looping around to that port.
The rear most port on the EGR solenoid vacuum connector goes to the EGR valve. The forward one goes to a "T" fitting up under the plenum just behind the throttle body, the other side of the "T" goes to the evap. cannister.
Old Apr 5, 2004 | 01:43 AM
theSteve's Avatar
Car: 1985 Trans Am
awesome. thanks for the help.
Pac J
May 17, 2020 10:44 AM
mrbird
Oct 20, 2015 03:43 AM
djmarch
Oct 2, 2015 10:41 PM
Lmancha96
Sep 25, 2015 08:11 PM
