Swapping 305TPI > 355TPI - PROM/Injector questions?
Old Apr 14, 2004 | 04:33 PM
bigbangtech's Avatar
I have a 1986 Trans Am with 305tpi/700R4 and an ADS chip(original chip is MIA)
I'm building a 355 to swap in since the 305 is toast and I have some concerns about the fuel system:
1) Are the stock 305 injectors going to work with the 350?
2) Is the 305-calibrated chip going to work with the 350/stock injectors
3) What about 305 chip with 350 injectors?
4) I'm pretty sure that the stock PROM is 32B with 1227165 ECM. Does anybody know what the PROM for '86 350 is (guessing camaro since TA didn't have 350 that year)
Old Apr 14, 2004 | 04:50 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Get bigger injectors(probably 24#) and get an new prom from a 350.
Old Apr 16, 2004 | 01:23 AM
Kevin Gray's Avatar
Re: Swapping 305TPI > 355TPI - PROM/Injector questions?
The 305 chip will usually work OK on a MILD 355 with an AFPR as long as the 305 injectors are used. Running a 305 chip (19# injector constant) and using 350 injectors (larger 22# injectors) will cause a rich condition. The chip and injectors need to match --- 305 chip with 305 injectors or,,,, 350 chip with 350 injectors.
Neither the Camaro or Firebird came with 350s in 86. However, if you go with 350 injectors,,, check the FAQ section of this board (link) for the PROM listings and pick the 1987 or 1988 350 chip that matches your gearing.
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Old Apr 16, 2004 | 10:12 AM
Steve89GTA's Avatar
The best solution is to get a chip burned. The larger injectors will confuse the computer but it WILL be able to compensate in closed loop by using the other sensors (considering they are in good working order) and will be able to compensate. At WOT (power enrichment mode), you will run pig rich as the computer will rely on preset settings and not the sensors.
Old Apr 16, 2004 | 07:59 PM
What about adjusting the injector# constant from 19# to the 2x# of a 350 injector if using 350 injectors?
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
