Anybody Using one of These
Old Apr 24, 2004 | 01:48 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Just wondering if anyone has used this and what you think of it.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT
Old Apr 24, 2004 | 03:41 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Hehehe... I have very recently changed my world view concerning RAM AIR.
Basically, the guys with the logged data debunked the RAM AIR myth. Don't let that dissuade you from getting this setup tho - it is excellent for true cold air.
Refer to this thread and learn something... I know I did.
https://www.thirdgen.org/techbb2/sho...hreadid=235271
Old Apr 25, 2004 | 09:11 AM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
that guys a stroke I was giving him **** about them once before. Using those will help; however; the nose on the front end of the camaro is lower than a formulas, and they rely on the air coming through the louvers, where the fog lights are located just as much as the air dam below the car, and it may effect the cooling effect, and you will get alot more dirt into your filters, and if your in the rain, the water is definitely going to enter your filters, and if driven long enough, it could pass through the filters, and enter MAF, destroying it, gm high tech learned the hard way when they designed there own setup for ram air.
My Site:http://www.cardomain.com/id/cronsformula
Old Apr 25, 2004 | 10:30 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Get some nice mesh screening to block it off. That will help with dirt and stuff if you are worried. I don't think 1Bad91Z has any problems with his setup and its pretty much the same! (ask him)
