fuel pump
Old Apr 27, 2004 | 03:47 PM
87camaro kid's Avatar
Car: 1987 Z28
fuel pump
everytime my car gets to operationg temp. everytime i stop at a litght or just put it into drive my car stalls...what could be causing this...all i could think of is the fuel pump
Old Apr 27, 2004 | 04:09 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Have you checked for any codes? My car has done the same thing in the past. Once it turned out to be the MAF, once it was the timing was way off, and most recently(last week) WinALDL was showing a code 34. Turns out, that was a false code 34 because I have a crappy '870 ECM. That should not be the case for you. I would check for codes though. When was the last time you replaced you fuel filter?
Old Apr 27, 2004 | 06:27 PM
Car: 1987 Z28
no codes i hu it up to a computer to cheack and everything was running fine the only thing i noticed was that when it was about to stal the voltage on the fuel pump droped
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
