C207 connector for 87 305tpi
Moderator/TGO Supporter
Car: 1997 Z28
Does anyone have a diagram showing the c207 connector and the c100 connector for an 87 305 tpi.
I have one for an 89, but its different, so i think 87 may have had some differences.
Any help would be great, thanks in advance.
Car: 1997 Z28
Which one of these would i want to plug in g4 of my 91(fuel control)
It doesnt seem to mention fuel control.
I need more information. I don't know what you're trying to do. Are you installing a 87 harness into a 91 car? By "fuel control", do you mean the tan/white wire (if 87) coming from the fuel pump relay that supplies power to the fuel pump? If so, the tan/white wire that supplies power to the fuel pump in 87 goes through a gray connector (can't remember the connector number) that is located near the 15-way I/P harness connector, near the ECM. Also going through that connector are the injector power wires and backup switch wires (blue and green) if you have a manual transmission harness.
If this does not answer your question, I need more information about what you're doing.
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
What Tim is doing is swapping a 305TPI from an 87 TransAm into his 91 Firebird v6 car.
The motor is in, I think the exhaust is done. But they aren't getting any injector pulse, nor will the fuel pump turn on.
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
