probs w/85 t/a starting cold
Car: 85 T/A
Engine: 305 tpi
i have 85 t/a that is having probs starting cold. i've done plugs, wires, ing module, iac, tps, o2, and cleaned the throttle body to be free of the carbon build up. it has check eng on, but only throwing code 12. it was starting cold only, then would die, until warmed up, so replaced iac and tps, now my prob has reversed. it only starts when hot. the only it will start right up cold is if you are checking computer codes with the good ole paperclip. as soon as you pop in the clip it fires right up and run just fine. after its started that way, i can pull clip out, and go no problem. it restarts no problem once warmed up, any suggestions? other than keeping a paperclip around to start it in the morning?
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
