help
Old May 30, 2004 | 12:05 AM
purplebird's Avatar
Car: 1992 firdbird formula
Engine: 5.7 tpi
help
I just installed a new custom made cold air intake. Also put on a new starter. Now when i'm driving, i can give half gas up to 6 thousand rpm's. But when i give it full gas it will not go above 4 thousand? I do not know if it has anything to do with the starter or the cold air intake. Can anyone help me
Old May 31, 2004 | 09:48 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: help
Starter: no
CAI? Maybe. You are trying to push more air into a small opening, (i.e. stock intake). It could be causing a negative effect. Your intake is only good to 4500rpms anyway. It may be there is too much turbulence at WOT. Only guessing... With more air you need more fuel (bigger injectors) and less timing. Your speed density system doesnt take kindly to mods without chip burning.
Old Jun 1, 2004 | 02:09 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I would check the TPS, you might have moved it some and that is causing your problems.
