Airflow sensor question
Car: 1989 Iroc-Z Camaro
Engine: 5.7 liter 350
Alright, I have a 89 iroc with the tpi 350...I am looking for a new mass airflow sensor and do not know exactly what would be compatible. Are all 82-92 one's for tpi engines compatible?
All I've seen from reading post after post is bosch and delco..many on ebay don't tell what company they are from though.
Some are really expensive, and some are pretty cheap (some used). I'd like to get the right part...got the wrong injectors lil while ago and ended up costing a bit of time and money. Thanks-Chris
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you are going to buy one I would get the Wells MAF. With screens it flows more than the stock one without screens. I have seen prices quoted at around $170 for the Wells MAF. Someone may have more info. Allen
If I were you I'd personally go for a new Wells Su145 MAF.
I wouldn't risk parting with the cash for a used MAF sensor. Chris, have you confirmed that you MAF sensor is knackered? Have you tried running without it connected?
However, in internet land there are always varying opinions and different people will say they had problems with different parts.
Some threads to check out:-
Wells MAF. Where?
https://www.thirdgen.org/techbb2/sho...ight=wells+maf
Wells MAF = Bosch MAF
Which MAF to use
Anybody know any internet place to get Wells MAF?
https://www.thirdgen.org/techbb2/sho...ight=maf+wells
Best priced MAF
Mass Air Flow Sensor
Anyone have flow numbers for the su-145 maf and other intake tract parts?
Wells su145 maf
Calling all wells SU-145 MAF users...
Wells MAF. Where?
Which MAF to use
Best priced MAF
Wells su145 maf
mechanic said that it was the mass airflow sensor, thanks a ton for all the info, im gonna read through it all tonight, i cant right now, but thank you so much
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEDW%3AIT
that is probably no good huh? its soooo cheap though, and he has another.....damn
