is it time for new injectors? after new heads?
Old Jun 12, 2004 | 08:16 AM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i just installed a new set of ported 6085 heads with Edelbrock base. man it ran like raped ape, barked 2nd easily and stronger above 3000 rpm. so being greedy and asking for more.. i installed 1.6 comp magnum rockers on my 08-501-8 cam and now when i am in overdrive at about 1800 rpm and i hit an incline and litely throttle it, the engine seems to hesitate abit but if i accelerate a bit quicker through that rpm rage it isnt as bad. so i double check tps, iac, timing set at 8* and it wont cure it. bump up f.pressure from 43 stock to as high as 50psi and no improvement. all new ignition parts and fuel filter and fuel pump. can a engine have to "much" lift i previously has stock stamped rockers on it. my cam specs are in the sig. oh by the way then engine seems to scream louder when i mash it after the 1.6 rockers.
Old Jun 17, 2004 | 05:43 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
wow... 30 looks and no opinions?
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
italiano67
Dec 11, 2016 09:21 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
