View Poll Results: Most cost efficient performing intake for 400HP 383.
Super Ram
22.22%
Stealth Ram
31.11%
Mini Ram
24.44%
LT1 Intake
15.56%
Ported and Siamesed stock TPI
2.22%
Carb
4.44%
Other
0%
Voters: 45. You may not vote on this poll
Which intake for 383?
Old Jun 30, 2004 | 10:14 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I am trying to decide on the most cost effiecient yet good performing intake for the 383 that I am going to be installing. The engine had 405HP and 445TQ on the engine dyno. I would like to stay with EFI rather than Carb but if it works better and is cheaper I will. If anyone could give me some ballpark figure for these different intakes that would be nice too.
Old Jun 30, 2004 | 10:53 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I'd honestly go with the LT1 intake or Stealth Ram. Best bang for the buck and I like EFI over carbs. Can't go wrong with either. With that cam and cubes, LT1 *may* be a better choice.
Old Jun 30, 2004 | 10:58 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Superram.
Old Jul 1, 2004 | 12:06 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Depending on combo and where you want the powerband to be...
In the right combo all intakes can make good power at diffrent rpm, just decide where you want it to be and then buy intake/cam/heads for it...
Also consider emission, some intakes dont have EGR....
/N.
Old Jul 1, 2004 | 01:19 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Well the engines HP was 405 at 4800 RPM but is pretty flatlined from around 3800 and up. The same for the TQ. The cam that it has is a 234/244 114LSA. I'm not sure about the lift. It has Dart heads. Does the stealth have EGR?
Old Jul 1, 2004 | 01:29 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Heads ? how big?
Where do you want he power?
HSR dont have EGR.....
Old Jul 1, 2004 | 01:41 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I am pretty sure that the heads are 62cc with 2.02/1.94 three way valves.
Old Jul 1, 2004 | 01:42 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
180cc? 200cc? 220cc?
Old Jul 1, 2004 | 02:14 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Sorry, just double checked. They are 215cc, 64cc, 2.05/1.60 valves.
Old Jul 1, 2004 | 01:10 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Just realize the LT1, TPI, and SuperRam are the ONLY ones that are certified for emissions. If you have a visual check the others could cause you to fail and then you'd have to replace them.
Old Jul 1, 2004 | 01:38 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
If you are going to stick with your 700-R4, then I would say you'd be best off with the widest powerband you can get, ie. the super ram. I feel that the other reasonable options (sorry but I am not even considering the LTR setup) are better suited for a manual tranny, ie the mini/stealth/lt1. John lingenfelter has a good section expaining the theory behind this opinion in his book.
Old Jul 2, 2004 | 08:10 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
From what I recall, the HSR cant be port matched to 215cc(1206 gasket I think) heads without adding material.
Old Jul 7, 2004 | 10:11 AM
Dr G's Avatar
BuckeyeROC:- You say that, yet you ran absolutely fantastic times in your 355cid with AFR heads and with SuperRam on top. Does the price of it, or the installation hassles now put you off SuperRam? Just curious.
Old Jul 8, 2004 | 09:11 PM
BuckeyeROC's Avatar
Only reason I say that is b/c I thought my combo was too mild. Kind of subjective. It was originally built for daily driver duty but became a weekend car, so I would have gladly traded off the tameness for more power and better times. Don't get me wrong, it ran GREAT. And for a daily drivable car, it ran awesome times and spanked a lot of cars on the street. I still feel there is NO OTHER intake for our cars that will outperform the SR "under the curve" to 6k rpm. It does work very well. I just ended up wanting something faster for a weekend car and learned that I could personally tolerate a much more radical combo.
As you can see in my sig, I'm going the complete opposite direction with my LS1. It's now my weekend car. The cam is 243/249 .608"/.613" 110 LSA and I'll be shifting at 7000 rpm. When the 4.10 10 bolt bites it, I'll probably end up w/ a spooled rearend w/ 4.30's or 4.56's. MUCH different from the IROC's combo. BUT, it should also run solid 10's N/A once I get some AFR 225's and do a manifold swap.
Streetability, drivability, etc. differs for everyone and differs between daily drivers and weekend/track cars. And once you run certain times for awhile, they start to seem slow to you and you want more. That's all. Nothing wrong with the combo I had, just got old to me. But it was very effective. Knowing what I know now, I would go with a bigger cam and an LT1 intake (which wasn't even an option at the time the motor was built).
Old Jul 9, 2004 | 01:59 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Are there any modifications that need to be done for the stealthram to bolt up to a set up Dart Iron Eagle heads? What about the TV detent cable? Also, I am thinking that I will have to use SVO 36lb injectors since the HP should be pushing around 400-450. Anyone using 36lb injectors? One more question. Will I have any problems with my MAF sensor with the Stealth Ram or the Super Ram? Just worried that it may restrict flow.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
