tpi to carb
Old Jul 12, 2004 | 11:17 AM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
tpi to carb
hello:hail:
I did the swap already as the tpi will go into a different bird.
here is my questions.
#1. What parts of the wiring harness do I need to remove fronm the car?
#2. Will the car still function after the wiring harness that conect to the computer are removeed? (meaning the lites, radio, power accesories, ignition and such)
thanks
and
GB
rick kiing
Old Jul 15, 2004 | 12:08 AM
wulff's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 TPI
Transmission: T56 6-speed
Yup! There are several sections that are 'wrapped' into the harness that runs the lights, etc.... and if you disconnect the sensors you will still have lights, horns, etc. I would leave as much as possible still in place and just try to unplug sensors, etc.. in case you want to go back.
Don't forget you won't have the knock sensor, distributor, timing, converter lockup (if it's a an auto tranny) or any engine managment systems etc, anymore as these are all computer controlled. Also, it will no longer be street legal nor will it pass emissions without the computer but I'm sure you have already considered that.
Good luck..
Old Jul 16, 2004 | 12:08 AM
Rick King's Avatar
Car: 1987 TA
THNAKS
LATER
rk
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
