406 Passed Emissions!
Old Jul 18, 2004 | 08:17 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
The motor is a 406, 11.0-1 comp., Comp solid roller, Brodix RR200 heads, MiniRam, 58mm TB, 36# inj, Hooker Super Comps and dual 3" catco cats.
Last week I had my emissions tested here in Ohio at the E-Check.
HC - 78.9 vs. limit of 1.44 pass
CO- 1.63 vs. limit of 0.92 Fail
NO - 141.3 vs. limit if 1014.0 pass
A reply by Red Devil in some earlier post about failed emissions helped me out. Basically the motor was running well just on the rich side. I have a DFI so pulling fuel out in the desired rpm was not a problem.
Yesterday I retested.
HC - 1.35.5 vs. limit of 1.44 pass
CO - 0.05 vs. limit of 0.92 pass
NO - 199.5 vs. limit of 1014.0 pass
I believe that the HC went up due to the fact that I pulled too much fuel out and it had a periodic lean miss. The good news is that it passed and I'm clear for the next 2 years.
www.geocities.com/dzperf
Old Jul 18, 2004 | 08:30 AM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
Mine passed Echeck to even though my 406 is alot milder than yours. I built it still wanting to pass emissions. I had to put a cat on, temporary put my AIR back on(and backed the timing off) and passed with flying colors after I failed miserably the first time.
Old Jul 18, 2004 | 02:27 PM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
you're my hero makes me less afraid of the evil emissions people as i beef my 383 up
Old Jul 18, 2004 | 09:37 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Let this be a lesson to all that think big cams can't pass emissions. With cats and tuning/tricks it will pass.
Old Jul 19, 2004 | 03:27 PM
Scott57350's Avatar
Car: 1991 Z28
Engine: 355 TPI
hey wackytower im from parma hts also. i have a 91 Z its burgundy just put vortec heads and lt4 hotcam in. Your car looks good, I may need your help to have mine pass emmisions next year. Right now Im tring to get my tuning in but its a pain in the a$$
Old Jul 19, 2004 | 07:02 PM
wackytower's Avatar
Car: 1985 Trans Am
A bunch of local guys(NE Ohio) post at 3rdgen under the Midwest section
Old Jul 20, 2004 | 09:58 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Whats sad is my 383 motor passed cleaner then my 99 GP GT. Thanks to 89GTA383 for doing my chip. I'm still working out my Y pipe issues. From then on. I'll be working with the chip. All I had was a cat. I forgot to hook up my EGR and I have no AIR anymore or anything.
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
