quick and easy...
Old Jul 26, 2004 | 09:17 PM
grndmasnightmar
Guest
Posts: n/a
quick and easy...
what simple things cause a car to run rich. no explanations required.and can a bad cts cause this prob? like i said you dont need to spend much time here i know its been covered i just wanted it layed out simple. thanks alot guys...
Old Jul 26, 2004 | 09:22 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Oxygen sensor.
Old Jul 26, 2004 | 09:44 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Yes, a bad CTS could make you run rich, if the CTS is bad, it usually always thinks the car is either warm or cold... if it thinks the car is cold, it would tell the ECM that the car is cold, and give it more gas, to keep it running... since a cold engine usually needs more gas to run alright.
Otherwise, Leaky injectors, or bad 02 sensor. Or if your maf is bad and reading high all the time, but I think you'd have drivability problems then.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
