tpi
tpi
i am planning on on tpi swap from carb, i have a 86 ta that has everything needed for this but today i was pulling ecm out and found a yellow box labeled buffer attached to the ecm do i need this for the swap? and how do i tell if it is speed density. and my car doent have a furl pump in the tank can a after market puimp be used.
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Easiest way to tell if the ECM is SD is it will have three connector plugs, MAF ones only have two. Also there should be a part number on it somewhere that ends in 730, MAF's end in 165.
And yes, you can use an aftermarket fuel pump.
Not sure about the buffer box.........
Sanjay
Aug 12, 2015 03:41 PM
