have a quick injector question
Old Jul 28, 2004 | 05:06 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
im building up a lt1 cam, ported heads and ported tpi on my lil305
i would like to use a stock 350 prom to start with to get it to run but i only have #19 injectors
i have the stock #28 injectors out of my 2002 and they are rated at 60 lbs of pressure
at 40 lbs of pressure these injectors would flow just over 22 lbs
would this be exceptable?
thanks
joe
Old Jul 28, 2004 | 07:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think I'd just stick with the 305 chip, and tune from there...I don't think the LT1 cam compensates for 45 cubic inches.
Old Jul 28, 2004 | 08:49 PM
jerflash's Avatar
or would it be better to use a 305 manual bin and it to auto so i have a closer spark and fuel curve then now and still be a 305
thisnk thats the way to go?
Old Jul 28, 2004 | 11:17 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Probably a better suited question for the PROM board, do you know if there is a difference in the curves between the auto and manual? I'd assume there's things in a manual bin you wouldn't want in the auto....I'd still tune with what I had, especially if you're just going to make the spark curve more aggressive and add more fuel to each table.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
