Please help me. Loads of water out tail pipe
Old Aug 19, 2004 | 08:36 PM
olong_us's Avatar
Car: 1986 IROC Weekend, Jetta VR6 Daily
Engine: 350 .030 over 5.7 TPI
Transmission: 700-R4 Rebuilt
Im still getting loads of water out my tailpipes it gets worse as the rpms go up. Ive replaceds all the gaskets from the heads and up. timings abit off though. Also now their is whiteish smoke. From the cat back the exhaust is new. Please help! Had the heads resurfaced. Were off .002.
Old Aug 19, 2004 | 08:51 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
That water is most likely from your cat.
Kevin
Old Aug 19, 2004 | 08:57 PM
clippjr8's Avatar
could be a cracked head. i dont know the rest of the story but water in the tailpipes is not good. If that gaskets are good, then the head must have a crack in it.
Old Aug 19, 2004 | 09:14 PM
olong_us's Avatar
Well when the heads where out i had them magnafluxed too and the came out ok w/ no cracks. Any other ideas? Thanks
Old Aug 19, 2004 | 09:19 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
could be a hair line crack in the water jackets. I had a NASTY surprise when I tore my engine apart to fix what I thought was a blown gasket.
Twin 4" long cracks on both sides of the block between cylinders 4&6, and 5&7!!!!! VERY big cracks!
Old Aug 31, 2004 | 10:43 PM
formulaman's Avatar
You could give that ceramic engine sealer a shot.
Old Oct 25, 2004 | 09:57 AM
olong_us's Avatar
its been awhile but i got some ceramic sealer i need to put it in. I have noticed that the collent does look good and the level hasnt changed. I dont think it could be the cat but i dont konw for shure. Any other thoughts on it
Hotrodboba400
Dec 10, 2019 07:07 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
90formulaVortec
Sep 7, 2015 07:17 PM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
