Power increase with LT1 intake
Old Aug 22, 2004 | 02:28 PM
lancerracer's Avatar
Car: 1988 T/A WS6
Engine: none right now
What kind of power gains can be expected by adding an LT1 intake (and correct cam) to my mostly stock 1987 L98?
Old Aug 22, 2004 | 05:49 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
In my opinion you would be better off doing the exhaust system first. You will bee a lot more gains. You will need a good flowing exhaust system to see any good gains from the intake side of things. Allen
Old Aug 22, 2004 | 09:38 PM
Car: 1988 T/A WS6
I understand that, sorry if I was to vague, I am saying to use the LT1 intake after exhaust etc. sorry!
Old Aug 22, 2004 | 10:18 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Give me a few weeks, and I will have fresh numbers of what my setup now (IN THE SIG, w/ stock intake on it) will do w/ the TPI setup, and then hopefully the next weekend dyno on the same dyno w/ the LT1 intake w/ same TB and see what the numbers are. Nothing will be changed except the intake and the tuning. Same TB, same exhaust etc...
That is the plan at least... I will post definate numbers once I get it all straightened out...
Old Aug 23, 2004 | 06:11 AM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
Please do.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
neekolzun
Aug 24, 2015 04:59 PM
forstral
Aug 19, 2015 03:20 PM
sreZ28
Aug 14, 2015 07:48 PM
