LT1 rocker cover onto LB9
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
I just came across a set of LT1 rocker covers for cheap, figure I'd replace the beat up rocker covers I have now. Only thing is, the passenger side cover doesn't have a hole for the valve. What size hole do I need to cut for the passenger side PCV-looking valve, and what is the best tool to use to cut the hole?
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Hole saw made for metal is the best. You'll also have to fabricate an oil baffle though so that the engine isn't sucking oil off of your rockers, so keep that in mind. Probably could tack weld your stock baffle in place if you wanted to...
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
