Chevy valley pan gasket?
Old Sep 11, 2004 | 10:55 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Got a HSR yesterday, looking over the base I was thinking the runners are exposed to hot splash. Is there a chevy oil pan gasket made similar to what you use for other engs? Anyone made one for their HSR? Did not come up with on using search.
Or does the retainer double as a splash guard? I use to working with non-roller blocks.
Old Sep 11, 2004 | 11:48 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
We don't have spash shields as you think of them. There are lifter valley baffles, such as the one made by Moroso.
http://store.summitracing.com/defaul...moroso&x=0&y=0
Old Sep 11, 2004 | 01:36 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Only one listed is for 18 deg heads and states:
* Cannot be used with roller lifters.
http://store.summitracing.com/defaul...ffles&x=21&y=6
Old Sep 11, 2004 | 02:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Look carefully. It says:
Chevrolet: 262-400, standard and 18 degree heads, lifter valley baffle
Standard implies 23°.
You'd have to mock something up to use it with factory spider stuff. I've looked into it for a little bit, not long enough to actually figure something out.
Old Sep 11, 2004 | 07:16 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Was hoping to find one molded with the 2 intake gaskets into one peice. Do appreciate the input though.
ericjon262
Sep 11, 2015 06:07 PM
muttracing
Brakes
Sep 6, 2015 08:12 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
