Rocker Reccomendation
Old Sep 29, 2004 | 12:28 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Hey everyone,
Putting a 350 TPI into my car soon and wanted to know what rockers you all reccomend. The Cam:
Specifications:
* Advertised duration: 280 intake/280 exhaust
* Duration at .050 in. cam lift: 230 intake/230 exhaust
* Gross valve lift: .480 in. intake/.480 in. exhaust
* Lobe separation: 110 degrees
* RPM range: 2,000 to 6,000
* Rough idle quality
It is a kit by comp that comes with the springs to match and the timing chain. So what do you guys think for the rockers? and do you think it is a good cam?
Old Sep 29, 2004 | 10:22 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Re: Rocker Reccomendation
Originally posted by MakeitQuick92RS
Hey everyone,
Specifications:
Are you very good at chip tuning? Why not get a dual-pattern cam?
Get some Magnum Pro 1.6RRs
Old Sep 30, 2004 | 09:13 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Id get a set of ProMagnums.
What are you running for heads/intake?
Old Sep 30, 2004 | 10:05 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If you've got the money to toss around, get a set of Comp Cam Pro Magnum rockers like stated above. If not, get a set of Comp Cams Magnum roller tip. Avoid any aluminum bodied arm as aluminum does not have the fatigue resistance of steel.
Might I ask what the rest of the setup is going to be?
Old Sep 30, 2004 | 11:33 AM
Engine: 383 Stroker
The Heads are going to be stock for now...the intake/runners/plenum are the edelbrock ones, Headers are going to be shorties by hedman, exhaust is gonna be 3 inch all the way to my flowmaster 80 series, with a pro built 700r4 with corvette servo and boost valve, and the rear is gonna be a a 10 Bolt with an eaton LSD. Thats about it till I raise enough money to buy dart heads. Oh yeah and my buddy who works at kelley chevrolet is going to tune the computer and dyno the car. The project is just getting started so when it is done i will report back here with some numbers.
Old Sep 30, 2004 | 11:50 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
That cam will not be fub with a tpi setup ... Let alone tuning on the stock ecm. Will it run? Yes, but it wont be fun or very efficient either..
I ran a hotcam in a 350 and I wouldnt do it again using tpi :-) Been there done that and do my own tuning as well.
My 383 in progress is gonna end up around 216/221 and 500 lift :-)
Should idle like a stocker(close to it) and pull like a freight train.
later
Jeremy
Old Sep 30, 2004 | 07:27 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Agreed.
Im running an XR282HR, which has similar 0.050 duration numbers and LSA to the one youre looking at, but Im running a modded HSR and 200cc heads. This cam is pretty aggressive for the street, and probably over the top for TPI. Youll need some converter behind it as well.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
