TBI to TPI swap advice
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Hi!
I have finally find a nice 350TPI out of a -89GTA whith low miles on it,and my question is what cam will be best for my new 350.
I have my compcam on the sig or a LT1 cam from a 95 Camaro,I just want it to be alround 300hp,and how much lift can the stock heads on that engine handle?
Thanks.
Thanks.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
the comp cam you have listed would work well, as would the stock LT1 cam. these cams would have a pretty smooth idle and lots of off idle torque. but with your 2400 rpm stall converter i think you can run a little more cam. i would look at some cams with around 210-220 degrees intake duration and 220-230 exhaust duration. you dont want a cam with too much duration or overlap becuase it wont work well with the tpi intake. but i would look for a cam that works from idle up to about 5500 rpm. my cam is listed in my sig and i have a 305, it works rather well.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok!
Thanks for the replay.
Do you think the zz4 cam will be a nice combo or do I have to to some work to my heads and what about the zz4 hot cam.
I belive that it isnt so big different betwen my cam :comp cam whith 206 intake 212
exhaust and vale lift of 480 in and 488 exhaust and a lobe angle at 112.
and the zz4 0.474"/0.510"
Dur. @ 0.050" (I/E) : 208/221 degrees
But maybee it will make a big difference.
I really like to build this engine right from the beginning.
Thanks again!
Thanks again!
Sanjay
Aug 12, 2015 03:41 PM
