Quick TPS question
Subscribe
Oct 26, 2004 | 07:54 AM
No time to search at work so...
I want to use an analog meter to test my tps.
Which wires are used?
Thanks,
Scott
Reply 0
Oct 27, 2004 | 10:55 AM
Should you even use a analog meter?
Reply 0
Oct 27, 2004 | 10:59 AM
I used one... use the power wire, and the ground wire...
You will know when you check it...
The ground is black, and I think the power was white...IIRC
Maybe wrong, but you will know when you start testing. One will give you a solid 5 V reference, and the other will give you a reading based on whether the TPS is open or not. Mine never got up to 4+ like its supposed to, but it was in the upper 3s... w/ the scanner its in the 4s though...
Reply 0
Oct 27, 2004 | 12:58 PM
Hello Scott,
You can use an analog meter altough you will get a more accurate reading from the digital voltage meter. The two wires that you want to use when testing your voltage would be pin "A" (black ground wire) and pin "B" (dark blue TPS signal wire). Pin "C" is the 5 volt reference wire.
Reply 0
Oct 27, 2004 | 09:09 PM
Hey Trixter,
I just wanted to test for dead or erratic spots and I heard read somewhere that an analog meter was best for this.
But....
That doesn't matter now because I think I am cursed.
Check out my new addition to I must Have Charlie Browns luck
Reply 0
Oct 27, 2004 | 09:59 PM
Hello Scott,
Check your e-mail for definitions and yes I saw the movie "The Money Pit".
Reply 0
Subscribe
