Speed Density vs. MAF
Old Oct 29, 2004 | 08:43 PM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Planning on a TPI swap and I was wondering which is better, MAF or speed density? I MIGHT put a cam in it later on, but that would probably be the extent of it. Just was curious what you guys with experience thought.
Old Oct 30, 2004 | 01:08 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I am a speed density fan. MAF is tough and can be problematic. Some guys here know how to tune MAF but I think it is a big PITA. MAF is not for a novice in high performance tuning apps.
Old Oct 30, 2004 | 01:13 AM
nick418's Avatar
Engine: L98, Hemi 6.2
Speed Density it known to be quicker by a couple tenths of a second. I herd MAF can handle mods better
Old Oct 30, 2004 | 09:51 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
In my opinion I would go with which ever one you can find at the better price. I currently have a SD setup and tune it as well as tune my friends MAF setup. In tuning both of them I really can't give any recomendation on which one is better.
Just my
You can also use the function and read over the hundreads of debates.
Old Oct 30, 2004 | 10:42 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
they are both the same, don't believe the hype.
Old Oct 30, 2004 | 10:56 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I had no gains going to speed density when my car was mosty stock.
Old Oct 30, 2004 | 01:28 PM
nick418's Avatar
well of course so, your car is all supercharged up All stock is gonna seem the same to you
Old Oct 31, 2004 | 10:48 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
I know that I will probably get bashed for this but I switched to MAF from SD because it is easier to tune part throttle with the MAF system. My car is much more responsive with the MAF then it ever was with SD.
Old Oct 31, 2004 | 11:17 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
MAF, it's better because it's more responsive to changes than SD. That's why all the car manufacturers are using MAF now. It is much more accurate than a SD which is "guessing" at how much air is being brought in, the MAF accurately measures it.
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
