fuel pump question
Old Nov 12, 2004 | 07:39 PM
badass87gta's Avatar
fuel pump question
Want to switch from tpi to carb and swap the motor into my Monte Carlo while I am restoring my GTA. Are their provisions for and what do I need to run a mechanical fuel pump? What else am I looking at replacing for this to work?
Old Nov 12, 2004 | 11:37 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Though I'm not sure of any part numbers a 3 port fuel pressure regulator should allow you to use your stock in tank fuel pump. You just need to ensure it's made for a return line and the pressure can be set low enough for a carb.
Old Nov 13, 2004 | 02:00 AM
I want to put the engine in my Monte Carlo, which does not have an in-tank pump. That is why I want to know if I can use a mechanical one.
Old Nov 14, 2004 | 12:20 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Your GTA's engine block should have a block off plate where the fuel pump goes, I would imagine that a fuel pump from a carbed
F-body would fit on it.
The other thing is that your engine does not have the eccentric
lobe that would operate the fuel pump shaft. You might wanna to look into that.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
