will supperram plenum bolt to SDPC vortec base?
Old Nov 15, 2004 | 07:47 PM
comatose 88 WS6's Avatar
Car: Chevrolegs
as the question says, will it?
Old Nov 15, 2004 | 11:01 PM
92GTA's Avatar
I think it should if you can get the superram runners too...
Old Nov 16, 2004 | 11:56 AM
Car: Chevrolegs
yea, plenum and runner come together, im kickin around an idea to use the fast burn vortecs and the hot cam, not sure yet though.
Old Nov 22, 2004 | 01:01 PM
Ragtop89's Avatar
I want to say that there were some small clearance problems doing that.
Nothing that couldn't be ground out from what I remember.
Old Nov 22, 2004 | 02:10 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
youd have to do a search for the thread, but i recall taht you needed a smaller head bolt near one of the runners, and to grind the runner a tad to fit.
nothing a trip to the hardware store, and a dremel tool couldnt fix.
Old Nov 23, 2004 | 07:00 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I just did it ...had to countersink two intake bolts, the right side front, second bolt back & the left rear second bolt from the end. Picked up the bolts at the hardware store. Also like was said, a few spots to Dremel.
Old Nov 28, 2004 | 06:46 AM
IROCZ315's Avatar
The guy I sold my old SR to did this on his 355. He still hasn't finished installing it yet. It should be a potent motor.
84z96L31vortec
Aug 20, 2017 12:16 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
earlpote
Aug 28, 2015 10:42 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
